Case Tractors Discussion Forum |
my case 800 wont start
Author |
[Modern View] |
paul case
10-24-2009 14:13:22
i just purchased a case 802b from a friend 10 days ago. he had drove it home and shut it off 5 months ago and it wouldnt start. i found out that he had worked on the fuel tank and changed the fuel filters. when i got it home i bled the filters(it is a diesel) cleaned the oil bath air cleaner , bled the injectors,still no startie! i cant pull it because it is a caseomatic. it is a pretty straight old tractor . my neighbor said smeone he had look at it told him that it didnt make enough compression to start. sounds fishy to me because he drove it home? any help is appreciated. thanks
J Heitkemper
10-24-2009 21:07:28
Re: my case 800 wont start in reply to paul case, 10-24-2009 14:13:22
probably have fuel bleeding ISSUES to Clear Up .. they are no worse than any diesel of that era .....You Can pull 800 to start ....This is How ,,have a strong battery , place shifter in 6th or higher ,, While Rolling crank engine with Decompressor engaged on valves ,And Direct DRIVE lever engaged ... You will be able to tell when Tranny rolling drag begins to spin motor , At that point dump the valves on engine , AND IT WILL START .. 1st time i did this successfully I was 12 ,, OUT of necessity , because of a tired battery .. Used A hillside slope ..
Jerry He
10-24-2009 16:12:35
Are you sure the compression relief is not on? It will spin easily and not fire. There is a four inch handle under fight side of dash that should be straight down. some people shut tractor off this way.
greginIN
10-24-2009 15:27:18
them 800's are a bugger to start when they run out of fuel. I cut an innertube so that the valve stem is in the center of about 10" square then clamp it over the fill hole on the fuel tank with a large hose clamp. crack the fuel at the injctor pump and presure the tank with 5psi through the valve stem. tighten line when you get clear fuel,keep pressure in tank while cranking engine, works every time for me.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Welding Basics - by Curtis Von Fange. One of the most useful skills that an owner of older equipment can have is the knowledge and ability to weld. It seems like the older equipment can do a job, albeit slowly compared to newer stuff, but it tends to break more often. Many of the breakdowns are related to the implements that are being used: the disc, wagon or bushog are among them. Knowing how to fix stress cracks, reinforce weak joints by welding on steel support plates, or cutting and shaping parts and adapters out of raw stee
... [Read Article]
Latest Ad:
Looking for a useable engine head for 1929 McCormick deering 10-20
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
