Case 410B
bbaxter
10-24-2009 10:12:55
I am in need of Parts for my Case 410B with front loader. Which I have rebuilt the engine with all new parts. I just had the RH front spindle break and in need of one. The tractor is a Case 410B serial number 609995 the RH spindle part number is G14334. This used on a heavy duty front axle for utility tractors. I would also like to locate the left hand spindle in the heavy duty type with the hub. Their part numbers are G14335 spindle and G14339 hub. A previous owner had put on a standard duty spindle on the LH front axle.
caseman-d
10-24-2009 10:55:03
 Re: Case 410B in reply to bbaxter, 10-24-2009 10:12:55
Might try Hy Capacity or A&I, both have web sights or you may find dealer with books to find one by measurements. Might also be able to cross OEM number from Case.
caseman-d
baxter
10-30-2009 20:58:49
 Re: Case 410B in reply to caseman-d, 10-24-2009 10:55:03
Still no luck in finding front spindles for my 410B. Tried location recommended by caseman
caseman-d
10-31-2009 08:54:48
 Re: Case 410B in reply to baxter, 10-30-2009 20:58:49
I just checked with my local dealer and he told me part #'s G14334 and G14335 were retired and to check locator. You might have your dealer check the locator. Bad news is case wanted 779 for 34 # and 682 for 35 #. Part # G14339 was invalid. I also run the numbers through Vintage Parts and the Depot and struck out there also. Might have to check salvage yards.
caseman-d
This post was edited by caseman-d at 09:14:46 10/31/09.
