I cannot get the high low selector to go into low gear (i think its low, all the way down to the floor. I can push it down, and finally get it to go into low, but it will pop out. There is a big gap between low and high that will make it just grind. Also, can you shift while moving? (it has the shuttle transmission between forward and reverse). Its hard not to stall out the engine when shifting into 4th (highway gear) without really letting the clutch slip. Also there is a little lever by the floor that appears to be a pto lever, but the tractor does not have a pto. Any ideas on what this is for?
