Contemplating changing the gearing to slow down my VAI to be more like a VA / VAC.
What exactly would I need to change? Pinion shaft and ring gear on differential only? Or do the Bull Gears need to be changed too?
Do I also have to change gears 1-4? I don't care if the speeds match the VA / VAC exactly, just want to be able to go slower overall.
I should add this would be my first time splitting a tractor. Just rebuilt the PTO and differential brakes, but didn't have to split the tractor for those. So pretty sure I could handle it unless there's all sorts of special tools required.
