Case Tractors Discussion Forum |
case 1070 hydrulic valve question
Author |
[Modern View] |
russ turner
09-18-2009 07:11:39
My 1070 hydro valve has had failure of the thermal valves, pt. no. A 13794. They are plastic and the stem bends causing loss of presure. Is there any alternative to these plastic valves. Thank You RT
mEl
09-18-2009 17:07:54
Re: case 1070 hydrulic valve question in reply to russ turner, 09-18-2009 07:11:39
Not that I am aware of, the thermals warp because of extreme heat such as when the linkage is tight and doesn"t return keeping the system on high pressure for extended periods of times. They last for years otherwise. I would recommend just replacing them and take steps to keep the levers centering properly. You will not have a problem with them then. I have replaced lots of them and extreme heat is all that can cause it. mEl
russ turner
09-18-2009 19:52:59
Re: case 1070 hydrulic valve question in reply to mEl, 09-18-2009 17:07:54
Thank you mEL. We pull a swather cutting heavey crops in hot weather and the trans temp does get up there as there is no trans oil cooler. RT
Agri King
09-18-2009 22:26:06
Re: case 1070 hydrulic valve question in reply to russ turner, 09-18-2009 19:52:59
Why is there no Hyd. oil cooler?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
