Case 800
David Burns
09-09-2009 09:39:09
Need some hitch lift bars for a 1958 Case 800. Anyone got any parts?
Lamont
09-09-2009 15:22:29
 Re: Case 800 in reply to David Burns, 09-09-2009 09:39:09
What all do you need? I have two good lower lift arms, a hydraulic pump and valve assembly, and the rockshaft with the upper lift arms. I"m not sure if the upright arm links are good or not. I know they"re usable, but they may have been bent or broken as most are. Let me know what all you need. I"m in North Central Arkansas.
Denny Goedken
09-19-2009 12:03:18
 Re: Case 800 in reply to Lamont, 09-09-2009 15:22:29
If possible could you e-mail a picture fo a somewhat complete 800 case0matic so I can figure out how the aircleaner goes on it,.currently has a loader on it so they took off original one.Thanks
Lamont
09-19-2009 15:25:12
 Re: Case 800 in reply to Denny Goedken, 09-19-2009 12:03:18
Look on the left side of this page at "Tractor Photos" under the "Galleries" heading. Click on it and type "Case 800" into the search and go from there. You'll probably find all the pictures you need and have fun in the process.
