Post hole digger for 480B ck
TimMiller
I was wondering if someone makes a post hole digger for our backhoe that can mount on our tractor? It can go on the loader or backhoe I do not have a 3pt hitch for it nor does it have a pto installed so it would have to be hydraulic. We have tried the little 3pt posthole diggers in the past but they don't have enough weight on them to break through the clay we have.
I have a 480B and have thought of taking off rear bucket and making a bracket that would let a hydraulic digger swivel in all directions so its always straight and run it with the bucket hoses and controls . Be real handy to reach into those hard to reach places .
I have seen hydraulic ones in ebay "implements" that go on skid steers that you might be able to adapt. If you mount on back hoe it would have a lot of flexibility in placement as well as being able to push into the ground.
I was thinking of building one also that would run off the backhoe controls. What i thought i was going to have to do is add another remote to the hydraulic system to drive the hydraulic motor to turn the post hole digger. I could probably just use a hydraulic ball valve to turn it off and on. I found this site that seems like they have just what i wanted. I was looking at least the M series http://www.equipmentland.com/categories/backhoe_attachment/diggers.shtml
They sell models that are made to go through solid rock, so our really hard clay shouldnt be a problem. Then they have a mounting bracket that will mount it to the bucket.
http://www.equipmentland.com/products/belltec/diggers/mounting_kits.shtml
Then of course the tooling required I was looking at there rock augers.
http://www.equipmentland.com/products/belltec/augers/augers.shtml#puff
