limiting clutch of CASE 970
Author |
[Modern View] |
bigned
08-12-2009 15:47:12
I have just split my CASE 970 AGRI KING and taken out torque limiting
clutch, I have some wear but, would like someone more experienced to tell me what depth a plate should have on its working surface to be sure
that this is my problem ?
Roger (Mi)
08-13-2009 03:34:44
powershift torque limiter in reply to bigned, 08-12-2009 15:47:12
As mEl says, ordinally the torque limiter is NOT suppossed to slip at all except under a sudden shock load. It protects the powershift from damage. However, many tractor pullers will reduce the size of the spacers around the bevel spring to greatly reduce or eliminate torque limiter slipage. My son also increased the clutch pack pressure to prevent them from slipping. He would shift up when most other tractors were shifting down. He never had a powershift failure. That's one tough transmission.
mEl
08-12-2009 18:48:46
Re: limiting clutch of CASE 970 in reply to bigned, 08-12-2009 15:47:12
What was your tractor doing, you are not giving us a lot to go on. A torque limiter first starts to show itself going bad when you are in 4th gear. When you powershift at full throttle especially under load it will slide into the next ps range instead of a firm no slip engagement. They don't have much lining on them, if there are still lines on the facing maybe .020 deep it is not badly worn, I'm just pulling that figure out of my head but they are a set tension clutch and not designed for starting and stopping, just inching around as they absorb shifting shocks. What was your unit doing? mEl
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
