Case 580ck popping out of gear
If the shift lever can easily be pulled into neutral with little to no resistance, the detent ball spring is broken or lost most of its tension. Another possibility is worn shift rail that dosen't allow the detent ball to firmly seat in the rail. Everything is in the shift cover. If a rail is being removed, make sure to cover the hole in the cover with a rag where the detent ball is located. Otherwise, that detent ball will fly out, and you'll spend the next three days looking for it.
