Case Tractors Discussion Forum |
Case 530ck diesel engine miss and knock
Author |
[Modern View] |
Bozrae1617
08-05-2009 15:58:29
I have a 530ck diesel that I have put on about 35 hours since I purchase it. While using it last night it developed a miss at higher RPM and also seemed to have developed a knock somewhere that I can"t determine, not sure if the miss is related to the knock? When I bought it I replaced the clutch and pulled off the oil pan to inspect the bottom end. It must have had a recent crank regrind because of the undersized bearing. The engine ran excellent with no misses and still holds 50 psi oil pressure at an idle, even with the knock. I do not believe the knock is crank and bearing related, but the knock has a deeper tone, and sounds about the same low and high rpm. I changed fuel and oil filters 35 hours ago. It appears to be getting a good supply of fuel. Any ideas and suggestions on the problems would be greatly appreciated.
Roger (Mi)
08-07-2009 04:28:38
Not good news in reply to Bozrae1617, 08-05-2009 15:58:29
A few years ago, a fellow had a 530 Case diesel with a knock coming from the engine. The oil pressure was good. When I pulled the oil pan, #3 connecting rod bearing was bad. The knocking came from the loose connecting rod itself and the #3 piston hitting the cylinder head. Had the crankshaft welded up then turned back to standard. Had to replace #3 connecting rod. Better pull the pan and closely check all of the connecting rods.
Bozrae1617
08-10-2009 10:23:28
Re: Not good news in reply to Roger (Mi), 08-07-2009 04:28:38
Thanks for the advice. I figured I may need to pull the pan off, you confirmed what I was thinking, I was hoping there would be a simple solution.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
The Collection of a Lifetime - by Sherry Schaefer. The larest gathering of orphan tractors ever assembled by one collector will be auctioned off on May 15 in Rock Island, IL. Ed Spiess was a well known tractor buff who spent most of his time dreaming of rare and unknown tractors. His background as an agricultural engineer sparked his interest in the unique attributes of the models built from 1939-1959.
... [Read Article]
Latest Ad:
Need a clutch shaft for a 46 Massey Harris 101 Jr., F162 Continental engine. About 18.25 inches long, to fit 1-1/8x 10 spline clutch disk. Bare shaft without sprocket or bearing is OK.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
