Case Tractors Discussion Forum |
LA water pump
Author |
[Modern View] |
DGKCCase
07-29-2009 10:49:33
Dose antone have a good used water pump for a LA Case or a rebuild kit.
DGKCCase
07-30-2009 03:26:30
Re: LA water pump in reply to DGKCCase, 07-29-2009 10:49:33
Thanks for the info,The bearings are good.I will try some of that grease and see if the leak stops. Thanks David
dboll
07-30-2009 15:08:54
Re: LA water pump in reply to DGKCCase, 07-30-2009 03:26:30
forgot to add some people use water proof grease for boats
Walterdavies
07-29-2009 18:29:49
Forgot, make sure that there is no pressure on the system, this is not a pressurized cooling system. Walt
dboll
07-29-2009 17:19:51
as Walt said grease should seal it if the shaft isn't loose, just 2 hardened steel washers for seals
Walterdavies
07-29-2009 14:31:29
I have a used one that was working in my tractor. If it leaks and the bearings sound Ok then just put some water pump grease (or hard grease) in the small cap on the top of the pump and give it a few good turns the drip should stop. I found water pump grease at the Lubriplate.com site. Its number is 115. Walt
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
