Anonymous-0
Just got my first Case every. It is a 1974 580B backhoe/loader. Bought it from a gentleman who used it at his farm/ranch and it only has 1500 hours on it. No leaks anywhere; pedals, front and back buckets, all sheet metal, decals, etc. are all in original condition. Minor surface rust only. Starts and runs great.
Want to change all the oil/gear fluids. There are 4 drains underneath the tractor. Know that
-- the one on the engine oil pan is for the motor oil.
-- also, that the one at the very rear is for the transmission and differential (this one has water in it).
-- the drain plug which is second from the rear is for the Torque Tube fluid.
HOWEVER, I have not been able to figure out what the third from the REAR plug is for?????????? From the front, it is the next one to the engine oil pan. I loosen the plug and there is thin fluid, but I don't want to drain it because I don't see where to fill it.
Have the Operator manual, but it does not explain this. Any assistance will be appreciated. Thank you in advance for your assistance. David
