Case 1370 trannys
bst
New User
Was the powershift the only tranny that they put into this tractor? I hear bad things about these. But then I heared there was an 8 speed.
Powershift only. The bad thing about them was the owners. A lot of farmers neglected the tractors. They would run them into the ground and then complain that they were no good.
My son and I installed an update kit into a 1370 power shift transmission. One clutch pack was held together with 5/16 bolts. The update kit changed them to 3/8 bolts. It wasn't that difficult to install. The late 70's already had the update kits and are very reliable.
Don't know the exact serial number when power shift transmissions were updated. Will need to check with a CaseIH dealer. The clutch pack with the 5/16 bolts will eventually fail by shearing off all of the bolts. You're on borrowed time. With the update, it's bullet proof.
