2670
Ohio Case
07-01-2009 12:39:36
Does anyone know the weight of a 2670? Also the weight of a complete 504 motor. Thanks
Jason Kozlowski
07-02-2009 21:57:11
 Re: 2670 in reply to Ohio Case, 07-01-2009 12:39:36
That sounds like it could be a shipping weight, so it's probably a bit conservative. Shipping weights are for a bareback tractor with no options, not even a radio. I have a 2470 that has 23.1-30 tires, I always figured it was at or near 20,000 lbs, to be safe. If you have duals, or loaded tires, it could be as high as 25,000 according to my owner's manual. Your 2670 wouldn't be much different, since the primary difference is the intercooler. Sorry, I can't help with the engine weight.
jcmarleau
07-01-2009 18:33:15
2670 weighs 17,785lbs with 18.4 X34 tires.
Ohio Case
07-01-2009 20:05:02
 Re: 2670 in reply to jcmarleau, 07-01-2009 18:33:15
Thanks for the weight on the tractor, would you have a rough guess on the engine weight?
