311 head light size
Dan Paulson
06-29-2009 20:41:18
What size head lights fit in the 300 series tractors? I think they must be around a 5inch but not sure also where do can a person get them, auto parts stores not much help aswell as the local dealer.
C. Amick
07-02-2009 21:00:06
 Re: 311 head light size in reply to Dan Paulson, 06-29-2009 20:41:18
Is it still 6 volt or has it been converted to 12 volt?
Dan Paulson
07-03-2009 14:20:49
 Re: 311 head light size in reply to C. Amick, 07-02-2009 21:00:06
They are 12volt now but I can put a resistor in and put it back to 6v. I the only ones I can find are either 4 1/2 or 5 3/4 but this measures out to be closer to 5inches.
C. Amick
07-03-2009 20:35:08
 Re: 311 head light size in reply to Dan Paulson, 07-03-2009 14:20:49
I used the 4-1/2 inch ones. I split a piece of rubber vacuum hose down one side and opened it up and siliconed it to the lamp. I used a very large band clamp to hold it in place until the silicone dried. The rubber hose is not visible once you re-install the metal light ring.
Dan Paulson
07-04-2009 07:03:38
 Re: 311 head light size in reply to C. Amick, 07-03-2009 20:35:08
Thanks I will give that a try. It seems that I found a place to buy 5in light on the web but can't remember the web sight.
