Company Logo Shop Now
Case 530 CK Loader circa 1960
Mike Foth
06-19-2009 20:35:10
Clutch frozen so I cannot tell if the pistons frozen. How can I manually turn crank? Any suggestions helpful.
Can I use the hydraulic pump on a PTO. What speed does it need to run on.
Roger (Mi)
06-20-2009 05:36:46
 Does it have an electric starter? in reply to Mike Foth, 06-19-2009 20:35:10
Obviously, the quickest way to turn over a backhoe motor is with the electric starter. To turn the motor from the front would require removing the front hydraulic pump. If it doesn't have an electric starter (missing? or remove it) use a pry bar, insert it into the starter hole, and try turning the ring gear. Forget turning the motor over by using the PTO. The leverage is all against you. The motor turns over at least three (540 PTO) times to the PTO's once.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
