Case Tractors Discussion Forum |
580ck water in oil
Author |
[Modern View] |
atlarge54
06-15-2009 15:39:46
Just purchased a 580ck at auction it was advertised as 108 hrs. on rebuild, has water in the oil. When I filled the radiator I could hear the water running into the crankcase at a pretty fair clip. Other than just checking the compression then pulling the head would anyone recommend checking anything else? Would the most likely problem be a head gasket???????
atlarge54
06-16-2009 01:34:53
Re: 580ck water in oil in reply to atlarge54, 06-15-2009 15:39:46
Would a piece of vinyl tubing installed on the lower coolant line and used as a coolant level indicator be a helpful diagnostic? Wouldn't this tell me at what heighth the leak is occuring? I'm talking about static testing, not with motor running.
mechanicfred
06-15-2009 16:32:14
Pull the oil pan and you'll see alot more.Is it running down around the push tubes, liner seals shot, block washed out or a host of other problems.
atlarge54
06-15-2009 16:45:17
Re: 580ck water in oil in reply to mechanicfred, 06-15-2009 16:32:14
I think the oil pan is cast iron and can't be removed unless the tractor is split. I could be wrong but it didn't look like it would be easy to remove. I was thinking about putting compressed air in the coolant system and possibly locating the area of the leak by sound??? Don't know if it'd be worth the effort though. What is the probability that I'm lucky and it's just a head gasket? If I check compression and get a low cylinder would that be an encouraging sign?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin
... [Read Article]
Latest Ad:
Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
