 I hope I dont confuse you any more, this has been an issue with my S as well. If you look for a voltage regulator for your regulator equipped generator, more than likely you will not find one listed. All I have seen offered is a cutout, but like yours, mine came with an autolite regulator. Also, the light switch on my S is just a push-pull on off. Someone correct me if Im wrong but, I believe if you use a cut-out , you have to use one of those expensive 3 position switches that control voltage to the lights. Its probably no big deal, but I did not not want to change the switch to use a cut-out. I was planning on getting to this a long time ago, just had too many other things come up. I met someone a while back with a massey 44, he told me that an echlin (napa) brand regulator # VR755 is what I need for the autolite generator on my case s, as well as the autolite generators used on the 6 volt masseys. The VR755 is still on the napa website, it looks identical to the one on my S, even has the little fuse holder on the side, and it mounts right to the generator as it should. If you can get someone at napa to see if it is still available and get you one , your in business. If you want, I'll pull the regulator on mine to see how the wires from the generator hook to it, let me know. By the way, the regulator has just one wire that goes to the amp gauge, Ihave some manuals somewhere for the S, I could probably find a wiring diagram if you need one, let me know....Tom
