Case Tractors Discussion Forum |
Compression leak in 2390
Author |
[Modern View] |
JW
05-26-2009 16:58:55
Have been using a 2390 on the disk this spring. Temp runs in the lower end of the green all day long. If you fill the radiator it will blow it out the overflow or out the neck if you start it with the cap off. Once it blows out about 2 gal its fine until you shut it down then it blows some more out the overflow. Is there a good way to figure out what head I need to look at? Any guesses to cause? Doesn"t run hot, no external leaks, and no water in oil. No blow by, lots of bubbling in radiator. I"m thinking head gasket.
toolz
05-26-2009 22:20:17
Re: Compression leak in 2390 in reply to JW, 05-26-2009 16:58:55
Sure sounds like a head gasket, but either way, it's putting compression in the coolant. My 1175 did about the same thing a while back. I knew I was going to have to pull a head, so I took off all the rocker shafts, pulled the injectors, and pressurized the cylinders with rubber tipped blo-gun. #4 was the culprit, so the center head came off and got a new gasket. Sure easy to work on these motors- pull the intake manifold and slip the head out. I do wish that Case would have used alignment dowels for the heads, though. Just dive in there- if I can fix it, anybody can!
Bugs
05-26-2009 20:29:07
I had a 1070 do this and it was that a small piece was broken off of the sleve lip at the top.The best I can remember is I pulled off water manifold on left side, took fan belt off so water pump would not turn, filled engine with water till water ran out manifoild ports, then started engine. I then could see which head had the air bulbs coming out of.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe.
... [Read Article]
Latest Ad:
Wanted front suit case weights and rear wheel weights for a 1456 international.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
