2390 oil cooler
steve il
i have just put the front half of a 2390 on a 1175 rearend. not sure if i am passing the hyd oil the right way through the cooler. also the lines on cooler seem to be tied together with a steel fitting about 5 inchs long, what does this do. any help would be great. thanks Steve
The pipe you are talking about is a bypass valve. Looking at the cooler, the top or inlet has two bends in it. The bottom or outlet has one 90 degree bend.
(quoted from post at 03:43:05 05/21/09) The pipe you are talking about is a bypass valve. Looking at the cooler, the top or in two bends in it. The bottom or outlet has one 90 degree bend.
thanks for the help i will check it out. Steve il
(quoted from post at 04:24:39 05/21/09) I would like to see you post some pictures of you project.
I will try to get some pics on. i also did a 1570-1175 3 years ago i will put it on too.
