1967 580ck backhoe wanted to know if anyone has a parts breakdown or a service pic breakdown of rear manifold on a model 32 backhoe that they could e-mail me the stabilizer section is leaking the return spring cap for the spool. wondring if i can remove spool from the top or bottom or both. i think that all i need is a o-ring also wondreing if i need to remove mainfold or split the section off or if i can remove the spool without removing the manifold. Also wondring if my seat on the backhoe that turns and adjust back should it also move up and down and lock in the up position for when using the hoe? if so how?
I need to get a service mannual wondering if i get an original off of e-bay will that only cover the tracter not the loader and backhoe or will i have to buy them too. I think the parts manual is separte from the service manual correct?
thanks for the help dan
