Company Logo Shop Now
Stuck fuel valve seat
Hunter134
04-26-2009 18:49:04
Thaought I was going to get my VAC started today, finished flushing the gas tank, new plugs , points, condensor, and coil. Hoked up the fuel line to the new sediment bowl turned on the fuel and gas ran right out of the carb onto the floor. Took the carb apart and am soaking it in aceton right now, but the fuel valve seat seems to be stuck tight, any tips on removing the stuck valve seat?
Nick@KY
04-27-2009 08:00:11
 Re: Stuck fuel valve seat in reply to Hunter134, 04-26-2009 18:49:04
Heat the seat and any jets you want to remove with a small propane torch.You may have to heat and let cool several time before it will come loose.Propane works better than acetylene because it does not get too hot.Good Luck and keep us informed. Nick
Hunter134
04-30-2009 06:54:47
 Re: Stuck fuel valve seat in reply to Nick@KY, 04-27-2009 08:00:11
Thanks got the seat out carb is back together, Hopefulyy I"ll have time to play with the tractor this weekend....
Latest Ad: 990 7 foot mower conditioner john deere hay rake pto driven john deere head carrier [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
