Company Logo (800) 853-2651 Shop Now
580ck
TJK
04-24-2009 12:31:49
My 68/69 580CK loader bucket can be tilted up, but will not tilt down. Every thing else is ok. I can raise and lower the bucket, just won't tilt down..the only work done recently was the small side cylinder was rebuild. The problem began after that. Any ideas on what the problem is?
mEl
04-26-2009 05:22:54
 Re: 580ck in reply to TJK, 04-24-2009 12:31:49
If the problem occoured after you had the cylinder rebuilt I would borrow a couple JIC caps and disconnect the Hydra Leveling cylinder completely at the valve. That would eliminate it as the cause, It is only a slave cylinder and will not affect the bucket roll except to defeat self leveling, however do not plug the lines at the cylinder while testing as any up and down movement of the loader will (not maybe) create pressures that would destroy something. Does lever travel seem ok in both directions on the bucket spool? mEl
casestudy
04-24-2009 16:06:54
sounds to me like a blockage at the ram or the pipe,take the pipe off the ram and check for obstructions it may be a piece of the hyd hose blocking it,you could also blow out the hose to check it too. has there been a new hose fitted to this ram? there may be pieces of rubber in it. other than that i'm not sure hope this helps.
This post was edited by casestudy at 16:11:36 04/24/09.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea ... [Read Article]
Latest Ad: John Deere DUBUQUE Parts for sale- 24 inch power adjust rims, 3 point hitch parts, Utility Rockshaft, Utility Anchor Yoke, 40 Standard ring and pinion, various 40 transmission gears. Other DUBUQUE parts available. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
