Crossmotor carb.
Jack J
04-10-2009 21:04:41
My 15-27 crossmotor has had the cork float replaced with a brass float from a JD.This float doesn't fit right and they have filed the inside of the carb to get it to drop low enough.Does any body make cork floats or what has everyone else done.I'am sure other people have had problems and not just me tring to find this out. Thank's Jack
gtx1967jewison
04-12-2009 20:58:20
 Re: Crossmotor carb. in reply to Jack J, 04-10-2009 21:04:41
yep! butchers- aint they somethin?
joeab
04-11-2009 06:30:38
You can get a float from Otto Gas Engine Works $17.00
Elkton MD 410-398-7340
Jack J
04-11-2009 09:00:41
 Re: Crossmotor carb. in reply to joeab, 04-11-2009 06:30:38
Thanks,will this be a universal type float that i'll have to fit or trim or do they make them for your carb.I wish I had one to compare to. Thanks Jack
Fred milner
04-12-2009 13:45:53
 Re: Crossmotor carb. in reply to Jack J, 04-11-2009 09:00:41
When you call otto they will send you the right float. The one you get will have a place for 2 screws but you only put one in if I remember right. it has been a few years since I replaced mine but it works good and fits right with no alterations at all. Fred
