Case Tractors Discussion Forum |
Any COM Experts out there, care to chime in?
Author |
[Modern View] |
Boyd B
04-08-2009 20:24:13
OK,, Got my ol' 800B running serviced the COM , new filter fresh Dexron. Took it for a test. COM pressure ran about 130 psi lock -up appeared to be working good. as the temp came up pressure dropped off and of course it stopped. Shut it down and let it set, checked the fluids, OK. Started up pressure came back up, moved good and then pressure started fluctuating from 0 to 130, sometime going up to 130 and slowly back down to zero, but mostly hovered between 40 and 80 psi. Even when it went up back up to 130 the lock up didn't appear to work. Almost act like it is sucking air, but no sign of oil foaming. still waiting on my service books, until then any ideas. Thanks
j heitkemper
04-09-2009 14:32:12
Re: Any COM Experts out there, care to chime in? in reply to Boyd B, 04-08-2009 20:24:13
I Will CONCUR with You Boyd , it does seem like its sucking air because of fluctuating pressure ,, how much fluid did you put in the 800?.....mEl knows alot that we don't know and I have gained alot from his schooling , and from everyone else too,for so many things , LONG LIVE THE FORUM .. best wishes, jim
Boyd B
04-09-2009 18:22:09
Re: Any COM Experts out there, care to chime in? in reply to j heitkemper, 04-09-2009 14:32:12
To be honest guys, I filled it out of a drum with no meter, to the the full mark. Ran it and rechecked the level static, not running. I know I did not drain 4 gallons out of it. I did not drain the Converter, just the case.
garytomaszewski
04-09-2009 19:18:50
Re: Any COM Experts out there, care to chime in? in reply to Boyd B, 04-09-2009 18:22:09
Did you check the oil right after you shut the tractor off ? The converter on mine will show over full if I check it after the tractor sets overnight.
mEl
04-09-2009 04:19:10
I am assuming that you checked the oil level immediately upon shut down before the TC had a chance to drain back. I would check the oil level with it in high gear running idling with the brakes locked, of course and fill it to level running. There should be a cold oil relief on the COM pump that could fail causing loss of pressure, there is also a pressure regulator piston assembly in the COM control valve that could stick causing a similar loss of pressure. The loss of direct drive when hot could be a loose fit between the bushing at the rear of the com unit where the pto drive shaft is carried as dd pressure is sealed at that point by simple bushing to shaft fit. I would clean the pressure regulators to get the pressure stable then deal with the dd as a seperate issue though when you get the pressure solved maybe the other will be ok, Lets hope, mEl
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner.
... [Read Article]
Latest Ad:
International 140 runs excellent very nice original tractor with original back tires. Always barn kept full set of cultivators. Tractor comes with original drawbar and cultivator wrench. Serial number 63788 hard to find one this nice. Delivery can be arranged if not to far out.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
