clutch problem with case 1570 tractor
cr85
03-20-2009 11:25:16
I have a case 1570 tractor and the powershift works fine. The problem is that when letting out the clutch the inching part doesn't work. The clutch engages at the end of the pedal with no slip at all. It makes it hard to start out. After the tractor starts moving the powershift works fine. Could something be out of adjustment or is the inching clutch bad?
coreyc
03-20-2009 18:02:23
 Re: clutch problem with case 1570 tractor in reply to cr85, 03-20-2009 11:25:16
I would start out with checking the modulator poppet in the rps valve.
cr85
03-22-2009 08:24:26
 Re: clutch problem with case 1570 tractor in reply to coreyc, 03-20-2009 18:02:23
what goes wrong with this poppet and where is it located
Thanks for you reply
coreyc
03-22-2009 18:50:09
 Re: clutch problem with case 1570 tractor in reply to cr85, 03-22-2009 08:24:26
On the right side of the tractor is the RPS(trans control valve). Locate the selector spool that the cable from the shift lever hooks to on the valve. On the bottom of the valve housing below the spool is a plug. Remove the plug, springs, washer, and the poppet. look at the end of the poppet valve to see if it is dammaged, if so replace.
