Garnet MacPherson
New User
I have a Case 311 and I need to replace
the fluid in for forward and rear of the transmition. I have drained all teh oils from both sections.
The front section is filled from a plug near the stick shift feeds the hydrolic pump for the three point hitch. What Oil do I use to fill this case and how much to I put in?
The rear section is filled from a larger plug in front and to the left of the seat.
It has a dip stick to indicate the fill level but I also want to know what oil I should use and its capacity.
I was considering using universal tractor fluid which can be used as lubricant and hydrolics however I wondered what would be best.
Does anyone have the asnwers?
Untitled URL Link
Untitled URL Link
