Re: Does every VAC have a broken block?
Stan
12-03-1999 18:29:19
To add to Alberta Mikes's story. It was almost 3 years that I searched for an engine to install in this otherwise cute little VA. And my friend Mike has this lead about two VA hulks. I pick them up, happier than the proverbial pig. The engines are both stuck for sure and I use one of the blocks to rebuild mine but you know the other block (which has only one piston stuck) had been welded!! And also on the left side. Interesting you say? But hey I've got all these parts. And my VA is looking mighty fine. Will get the final tune-up done in the spring (Is cold here in Alberrrrrta at the moment) and get Abe and the rest of the decals on. Grand-daughter Jenna loves to drive it around the yard. By the way, mine was a 49 as well. Now has a 48 block.
