Re: WC waterpump
Grandad
10-29-1999 21:13:03
In the parts manual it looks like it does indeed press off. You have to remember that hub was pressed on the shaft 50 or 60 years ago and is probably stuck pretty tight by now. I would try soaking it in a penetrating fluid of your choice for a few days and then using an arbor press to get it off. It will more than likely take a lot of pressure to get it moving. Some times a little heat doesn't hurt either.
