Re: WD-45
Ron
10-15-1999 18:28:50
If you get good compresion test and you are getting a steady miss, particularly at idle that goes away at higher speed, check for a leaky intake gasket. I usually spray penetrating oil (WD-40) around the manifold and carb with it idling. If there is a leak, it sucks in the vapour from the oil and speeds up or miss goes away for a few seconds. Ether works too, but use it sparingly.
Good luck.
