WD-45
OLY
10-10-1999 20:48:26
my old wd-45 is not running good, gave it a tuneup plugs/points,etc. but not having much luck, runs rough,not nearly the power it once had. where do i start and what do i look for? any help would be great, thanks oly
Dan Helm
05-21-2002 12:06:33
 Re: WD-45 in reply to OLY, 10-10-1999 20:48:26
I need a starter for my WD 45. Does anyone know where I can get one?
allis chalmers wd
11-12-1999 18:41:53
Ron
10-15-1999 18:28:50
If you get good compresion test and you are getting a steady miss, particularly at idle that goes away at higher speed, check for a leaky intake gasket. I usually spray penetrating oil (WD-40) around the manifold and carb with it idling. If there is a leak, it sucks in the vapour from the oil and speeds up or miss goes away for a few seconds. Ether works too, but use it sparingly.
Good luck.
Dave in Mo
10-15-1999 10:07:19
Could be the spark plug wires are leaking if they are old. They don't have to be brittle or cracked. Run the engine at night in a totally closed shed/garage and look very closely at all the wires for telltale sparks to ground. Sometimes it's quite a light show.
Carroll
10-14-1999 16:28:52
Compression test? Maybe a valve job , or just a routine valve adjustment is in order.
nlhoops@uswest.net
10-11-1999 21:24:37
Make certain spark advance in distributor is working
Patrick
10-11-1999 16:10:15
Maybe it's a fuel system problem. Is the carburator dirty or need adjusting? Maybe sediment bowl needs cleaning.
