Splitting a WD-45
Mike ISW
12-18-2003 14:03:02
I'm new to Allis's and would like info and/or hints on splitting a WD-45. Trans is jumping out of 3rd. Fella I know asked me about it and I'm partial to the RED tractors. After searching archives and coming up empty I thought you guys could help him and I out. Thanks, Mike
Matt
12-18-2003 19:16:42
 Re: Splitting a WD-45 in reply to Mike ISW, 12-18-2003 14:03:02
When I split my WD to do tranny work all as I did was get some angle iron (1/4" thick 2"x2") and bolt it to both sides of the frame rail at rear by tranny and welded plates to the bottom of the iron so it sat stable on the ground then removed both rear tires, and final drive housings. Then hooked a cherry picker to the tranny/diff housing and un bolted from tourque tube and frame rails and removed.
JMS/MN
12-20-2003 14:55:36
 Re: Re: Splitting a WD-45 in reply to Matt, 12-18-2003 19:16:42
The 2x2by 1/4 angle is strong enough to support the tractor, but you should have a wider base than the tractor frame. Sounds too tippy if they go straight down below the frame. Most splitting stands are an A-frame design, about five feet wide. Most stands would have casters, so you would block up the rear half of the tractor and roll the front end forward enough to work on the defective component.
wdTom
12-19-2003 18:35:08
Your idea for supporting the frame sounds good. But why not just put a dolly under the transmission and roll it and the rear end of the tractor back at that point?
Matt
12-19-2003 20:57:38
 Re: Re: Re: Splitting a WD-45 in reply to wdTom, 12-19-2003 18:35:08
That would work good also. I guess I was not thinking, I had the cherry picker there so I just used it, but the dolly would work fine too.
