Re: AC 180 DSL PTO PROBLEM
dd
07-10-2003 20:30:21
The only thing that I can think of (and I'm doing it from memory) is in the area of the lever that turns the pto on is a slide with detent in it. On mine that has froze up once and I had to adjust it or something. If thats where the problem is once you see it it should be self-explanatory, much better than my memory.
Jim
07-15-2003 14:45:15
 Re: Re: AC 180 DSL PTO PROBLEM in reply to dd, 07-10-2003 20:30:21
The slide collar that joins the drive to the PTO shaft is not sliding. Sometimes the splined end of the PTO shaft will burr not allowing the collar to slide.
