Company Logo (800) 853-2651 Shop Now
Re: Old abandoned AC
wdTom
07-09-2003 18:32:10
Look around the pictures and try to find one somewhat like it, then we can tell you where the serial nos. are and what model it probably is. Need more of a description, didn't see your attached image.
steve
07-09-2003 20:15:08
 Re: Re: Old abandoned AC in reply to wdTom, 07-09-2003 18:32:10
need a little info... If it is a little B or C, it will have no frame from teh transmission to the motor, just a round torque tube that has the draive shaft inside. It will have 24 inch rear wheels. The serial number will be by the transmission shift lever. If it is a bigger tractor like a WC or WD or 45, ther will be a c-channel frame from the rear wheels down each side of the tractor to the radiator. probably has 28 inch rear wheels. If it was built in the late 1930s it would be unstyled, meaning the gas tank looks like a tin can, and the hood and fenders are just flat panels, curved in one direction. The WC will have the serial number on the rear axle pumpkin. If it was built later on late 1940s and is a WD or WD45 the serial number is probably by the left rear brake cover, on the axle. These are the most common tractors prior to 1960. If it was built after 1960 it might be a D series and the serial number is behind the left rear corner of the motor on the torque tube housing on a flat boss. If it is a big old tractor from the 1920-1930 era, such as a U or A, i cant help. Post your e-mail and we can send you some pictures to compare.
Mike
07-09-2003 21:53:06
 Re: Re: Re: Old abandoned AC in reply to steve, 07-09-2003 20:15:08
thanks steve, I looked at the pics and it is either the filename AC-B or Aliis WC1. I know for sure it isn't the other two.
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
