Re: operating or parts manual
Thomas D. Smith
03-31-1999 12:04:07
Mr.Harold, When you say twin wheel do you mean it has two ground wheels or does it have two drive pulleys with a belt between to operate the wooden pitman arm? I just found out that a #7
mower can have two ground wheels but it does not have a wooden pitman arm to run the cutter bar,they operate from two excentrics right at the
end (where a pitman arm would connect). You might be able to locate some casting numbers and match them with other mowers. Tom ps: I have a manual for a #7.
