Re: WD45 Ignition
Dave Grubb
06-30-2003 08:13:18
Maybe or it may have had a resistor block inline with the wire. I use a NAPA # IC64SB coil. It is 12 volt and has an internal resistor(makes a simpler installation). The negative post of the coil should have the wire on it that is going to the distributor if the tractor is 12 volt negative ground. A lot of guys are using Autolite 295 or 303 plugs in their ACs now.
