Company Logo (800) 853-2651 Shop Now
Re: A-C model C power
steve
06-25-2003 18:58:19
compression ratio is about 6 to 1 so you can plane about 1/16 inch or a little more off the head (maybe .100) to get up to 9 or 9.5 to 1. you can port out the intake and exhaust ports to get more flow thru the head, then you can readjust the governor and install a slightly bigger carb jet to get 2-300 more RPM out of the motor. you can push it ia little harder if you want to take the risk. might talk to Dick L. on this board, he pulls the C and dose quite a bit of modification. Look back thru the old post till you find his e-mail. HE is alway willing to advise.
wdTom
06-27-2003 18:24:57
 Re: Re: A-C model C power in reply to steve, 06-25-2003 18:58:19
Don't know too much about C engines, have one but haven't taken it apart or thought of hot rodding it. But could you use pistons from the CA or later engines with more compression?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for 200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
