Re: 6060 good/bad
JoeinMO
06-23-2003 10:42:53
I have a 6060 for several years, I really like the tractor, now if I could find a 6080 I would trade it, the 6060 has 8 forward 2 reverse and the 60/80 had another 4 forward and 1 reverse, instead of a HI/LO it had 3 speed rear. The reverse on a 6060 is a little slow or fast if you are using a loader. They also seem harder to start in the winter, even below 50 degrees, I plug it in for a hour and it cranks up, but also could probably use a couple of fresh batteries.. I dont remember the HP rating, but works very well for me, we also run a older 180, but the 6060 is great with the PTO hand clutch, for bush hogging and cutting and haybaling. The only other issue I have is the parking brake, and mine has (had) standard hubs, had to buy heaver duty hubs for the loader. nice power, and GREAT on fuel! uses less per hour under load then the 180 and even that JD 340 lawn mower we have.
benny grant
06-23-2004 16:20:22
 Re: Re: 6060 good/bad in reply to JoeinMO, 06-23-2003 10:42:53
I am rebuilding the engine of a 6060 and I am looking for some specs. Main bearing torque rods Head torque Valve clearance Hope somebody can help me out. Thank you
