Company Logo (800) 853-2651 Shop Now
Re: Electrical Trouble
Steve in N.J.
06-21-2003 15:27:18
Mag equipped, or distributor? As the fellows mentioned, condensors are usually the culprit. Coils take a lot of blame, and get replaced without fixing the problem. Not saying that a coil doesn't go occasionally, but usually if it's mag equipped, the condensor fails. With distributors, could be the condensor, or a hairline crack in the cap near the high tension towers which eventually if not found, starts carbon tracking to ground, increasing the amount of times the tractor quits. Good Luck! Hope you find the problem......
Steve/B&B Custom Circuits
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
