Re: WD
Cooling System - Help?
Duey (IA)
06-20-2003 20:53:35
RP,
First, you may have the radiator overfilled. It only needs to be full enough to see fluid. The fluid will expand and over flow when hot if you have it too full. The thermostat should be located in the thermostat housing fastened to the head (what the top hose fastens to) With the top hose off you should be able to look in the housing and see the thermostat.
