Re: My B is burping....HELP!
steve
06-13-2003 18:22:20
I may be way off base, but i have a couple other ideas.
--it gets hotter than normal and the oil is thinner. those two things go together. maybe the thermostat failed or is stuck and you are not pumping as much coolant thru the motor? might want to pull the top hose and thermostat housing and look.
--back fire and popping can be valves sticking, or no clearance on cam to lifters. i would pull the valve cover and look at three things. 1. does each valve have .015 clearance at some point as you rotate the motor?
2. rap each valve stem on the top and see that the valve moves up and down easily in the guide.
3. look at the freeze plug below the valves in the head and see that no weaping of water is evident.
---good luck
