Re: WD-45 problem (Governor?)
Dave Grubb
06-13-2003 07:01:21
Sounds like the governor is getting worn or the linkages from the hand control/governor/throttle are getting a lot of cumlative wear that the governor cannot correct for. You might try running a string from the throttle link back to the drivers seat and gently try to add throttle with the string when the engine slows down. If you can add throttle doing that you probably have worn governor pins/weights. They are available for replacement.
Greggie
06-14-2003 00:14:32
 Re: Re: WD-45 problem (Governor?) in reply to Dave Grubb, 06-13-2003 07:01:21
Thanks guys, I'll take a look at that governor thing. That's knid of where I was leaning as we have went over the fuel and air recently.
Thanks again,
Greg
wdTom
06-13-2003 18:22:48
I expect you have checked the timming, and tuneup etc. What the other guys said. A 45 doesn't slow down much. Mostly the governor opens them up and they speed up under load. After all it is an orange tractor.
