Re: WD nf play in steering wheel and pedestal
Author |
John Rogers
06-09-2003 19:58:13
Kent; The square headed bolt you mentioned is actually a set screw that presses on a key between the bolster & spindle block. Quite often the key &keyways will become worn & it is necessary to file or machine the keyways & install a larger key. I have used both ways, but a good machine shop can give you a much better fit. Good luck, John in MO.
Kent
06-09-2003 20:05:47
Re: Re: WD nf play in steering wheel and pedestal in reply to John Rogers, 06-09-2003 19:58:13
John, Is there a way to get the up and down movement out of the "pedestal"? As I jack up the tractor the front wheels will sit on floor for @3/8" longer than the tractor as I jack it up. What takes this play out?? I have never had one of these apart and the parts/manual I have dont show it. Thanks Kent
John Rogers
06-10-2003 18:10:54
Re: Re: Re: WD nf play in steering wheel and pedes in reply to Kent, 06-09-2003 20:05:47
Kent, I would remove the spindle block from the pedestal by removing the bolt & shims &the setscrew, if it is loose on the pedestal it should drop right off. At any rate you need to remove it and replace the Timken bearing and race as they tend to wear grooves where the rollers set as most of the travel is straight ahead. If the bearing has locked up it may have worn a groove in the top of the spindle block.You can either file that off & use a washer there or the new bearing may take up the space. Then with shims or washers adjust things to remove any vertical play,Finally when you tighten the setscrew give it a few swats with a hammer as you are tightening it. John.
Kent
06-10-2003 18:29:32
Re: Re: Re: Re: WD nf play in steering wheel and p in reply to John Rogers, 06-10-2003 18:10:54
John, That is the info I was looking for. Looks like the Ole' Girl needs a new bearing and gears. Thanks, I appreciate the help. Kent
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
706 gas fuel tank&radiator
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
