Re: Leaning out a wd-45
Phill S. from M
05-30-2003 11:20:57
I had this problem with my 1954 WD-45, too. It has the same carb as yours. I kept trying to lean out the mixture screw on the bottom of the float bowl, but I couldn't ever get the mix right for both the top end and the idle end. Then I discovered that the choke rod and the lever that connect to the choke shaft had enough play in them that the choke plate was never opening up all the way! I was trying to adjust the carb with the choke about 1/3 on. Fixed this problem, readjusted the mixture screw and it's been running great since. Hope this might help you.
