Company Logo (800) 853-2651 Shop Now
Re: WD brakes, adjustable?
JMS/MN
05-28-2003 20:24:25
You asked about adjusting the brakes, not replacing them, like the others told you about. Yes, replacing can be a bear, getting the bottom pin out, but what also works is to drill a 3/4 inch hole in flat stock, weld it to the pin, and if the heat of welding doesn't loosen the pin, a BFH will do the job. Adjusting: take off the top cover on each side- left side is sheet metal, right side is the cast mounting bracket for the seat. Use a 3/4 inch wrench to adjust the nut you see after removing the cover. Tighten up each one until the brake pedals have the same amount of travel. End of job.
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
