Re: OIL IN #4 CYL
Author |
Kevin (FL)
05-15-2003 09:40:28
Dave,Run a compression check on all four cylinders. Write down the max pressures on each. Should be close to 100 PSI. The #4 cylinder may be lower. (Compression rings may be OK, but might have bad oil ring.) Whichever cylinder is noticeably lower than the others, squirt some oil in that cylinder and run test again. If pressure goes up, compression rings are bad. If pressure doesn't change, problem could be in valves. Then you would want to pull the head and check valves, seats and springs. The only other way I know to get oil in the cylinder is through a bad valve guide. Before I started tearing down the engine, I would do a little more troubleshooting. One other question--are you seeing much crankcase blowby coming out the breather when the engine is running? And make sure you have good plugs and good copper wires and all plugs are firing good. Report back if you can and we'll go from there.
Dave Wi.
05-15-2003 12:08:43
Re: Re: OIL IN #4 CYL in reply to Kevin (FL), 05-15-2003 09:40:28
Boy I hope yer right,asked once before about white smoke going up hill thought it might be a guide or pluged return,[white smoke oil,black gas] everyone thought it was water.If it's a guide might do the whole head,cant get at it till saturday.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
Latest Ad:
John Deere 71 planter parts. Hoppers, press wheels, sprockets, tons of plates and lots of other misc. Would like to sell as a package but might sell individually. Can text pictures.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
