Company Logo (800) 853-2651 Shop Now
49 Allis C
Jeff
05-13-2003 16:49:55
Hi Allis Guys,
I have a 49 C that I'm restoring. I have completely rebuilt the steering sector, the front pedestal and hubs. Recored the original radiator, New rear wheels and tires, All new brakes, New clutch and release bearing, As far as the engine goes I have replaced the cam bearings, rod and main bearings,new pistons,
sleeves and o-rings, head work has been done as follows: New valves, seats, springs and guides. Everything has been hot tanked. Finally the question:I haven't rebuilt the starter yet so I crank it to start it. Only takes about three or four cranks to start. As it gets warm it starts to miss. after running for ten minutes it seems to break up pretty bad. Is this a bad carburator or is it something in the mag? Thanks for all your help.
Jeff
Steve in N.J.
05-13-2003 19:30:05
 Re: 49 Allis C in reply to Jeff, 05-13-2003 16:49:55
Jeff, I rebuild F/M mags. If the problem is in the mag, here's a couple easy tasks to try. First, make sure the contact set is clean and the gap is correct. (.020) Also, sometimes the condensor may start to fail causing the engine to miss or shut down as it warms up. Make sure the plugs are non-resistor, & plug wires solid core and not suppression type. Also, inspect in the cover or cap (depending on which model mag) for any carbon tracking, which will cause a miss. If everything seems to be okay with the mag, it could be a fuel delivery problem.....
Steve/B&B Custom Circuits
rudy
05-13-2003 19:43:57
 Re: Re: 49 Allis C in reply to Steve in N.J., 05-13-2003 19:30:05
jeff the first thing i would be looking at is your valve lash when cold .010 thousands i think.as the tractor gets warm and valve lash decreases may be holding some valves slightly open hence the miss let us know how it turns out.rudy
Today's Featured Article - Identifying Tractor Smells - by Curtis Von Fange. We are continuing our series on learning to talk the language of our tractor. Since we can’t actually talk to our tractors, though some of the older sect of farmers might disagree, we use our five physical senses to observe and construe what our iron age friends are trying to tell us. We have already talked about some of the colors the unit might leave as clues to its well-being. Now we are going to use our noses to diagnose particular smells. ELECTRICAL SMELLS ... [Read Article]
Latest Ad: JD factory 3pt hitch fits 2 cyl 20 and 30 series tractor and 2 JD rear wts for late 2cyl and new gen Price 2000 for pkg calls only [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
