Re: A bizarre problem?
Author |
Brian Watson
03-25-1999 13:15:55
I agree with Ron. Sounds like your plugs are fouled. Look at them all, wet oily black carbon on them indicates oil fouling. This will happen if your engine uses some oil and never gets worked hard for long periods of time like when it was new and used for plowing. Fluffy black carbon on the plugs means too much fuel. Try leaning the carb a bit. The plug for this application if I'm not mistaken is Champion J-8. This is what should be used for heavy work. If you only use your tractor for light work or just riding around, try using a Champion CJ-14 or a J-19LM. These plugs are normally used in 2 cycle engines and are a hotter heat range to burn off oil. The suppression wires are only needed if you have or plan to use electronic ignition. Either way, start with a clean set of plugs. Hope this helps. Brian
Dave Fullmer (TN)
03-26-1999 12:01:46
Re: Re: A bizarre problem? in reply to Brian Watson, 03-25-1999 13:15:55
The plugs I always used in my Allis B and WC back in the 50's were H-10's. Because of my oil burners, I switched to the hotter J-ll plug. I am not even sure if Champion makes these any more, but you should be able to find a cross reference in the parts stores. I believe these were the standard plugs to use in AC tractors.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
706 gas fuel tank&radiator
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
