Re: AC/C narrow to wide front
Eldon
04-27-2003 12:12:02
I'm sure they will bolt right up....but to make it look decent I would put on a B stearing gearbox...otherwise the stearing rod won't be straight or it will stear backwards.
Kip Hansen
04-28-2003 15:48:33
 Re: Re: AC/C narrow to wide front in reply to Eldon, 04-27-2003 12:12:02
You will need the plate that bolts to the front of the engine, the steering box, & draglink off the B & everything will bolt right on. Helped one friend do a CA that way, & just helped another friend adapt a C wide front to a B. The only thing that was not strictly bolt-on for the B was triming the radiator shroud to clear the front gearbox.
