Re: Sparks at ground connection on AC B
Doug in OR
04-26-2003 16:51:04
If it is 12 volt negative ground, it was modified somewhere along the line. This tractor originally was 6 volt, positive ground.
As for sparks - this is a sign of a poor ground connection. Completely remove the cable at this connection. Clean the paint and corrosion down to bare shiny metal. Now clean the terminal on your cable. Reconnect everything, using a good clean bolt. After all this, paint or otherwise weatherproof this connection.
Now when you crank the tractor, you might notice a day and night difference in how fast the motor spins. BTW, this is a very common electrical problem. Many overlook it when troubleshooting - they aren't given the tell-tale sparks to bring this to their attention.
Eric
04-28-2003 20:20:17
 Re: Re: Sparks at ground connection on AC B in reply to Doug in OR, 04-26-2003 16:51:04
Thanks for the tip. It did the trick.
Eric
Steve in N.J.
04-26-2003 19:13:34
Eric, Doug is right on the money there. After your connection at the ground is cleaned and re-attached, a little dab of Dielectric grease will keep moisture out, and keep the connection corrosion free. If you think you may need a new cable, we have them available...
Steve/B&B Custom Circuits
